twister hammerhead 150cc go off road go kart
#21
Originally posted by: silverbullet2005
the new gander mountain store built by my house now carries artic cat quads and those twister carts your describing. they sell them for 2999.00. they are only 2wd. sams club sells about the same thing for a lot better price.
Where do get the performance CDI's for these Karts?
#22
Originally posted by: RAPTORAZ
Sam's carries the Yerf-Dog 3206. Which isn't as good as the Dazon/KPX/Twister models. It lacks reverse, front disc brakes, and ATV style hubs and wheels. I just ordered (2) KPX Xterro's from Toy Junkie's for $1999 each. I also ordered their performance kit(pipe, jet kit, and K&N) for an extra $300.
http://www.kpxmotors.com/unique.html
#23
[img]i/expressions/face-icon-small-disgusted.gif[/img]
I purchased a Twister Hammer head a month ago,
after 2 hours the reverse cable broke and the motor blew up, bad piston casting.
They sent me another piston and gaskets
after 1.5 hours the engine went again, same problem with the piston
they say that they have an updated piston design and are sending it to me,
if it goes again I will use the lemon law...
The cart is basically a good design and well built, The motor is a copy of a Honda, down to the color code of the wiring.
#24
#25
What happened was that the lower oil ring land gave way just above the wrist pin on both pistons, there is not much support there.
I took the barrel and pistons to my machinist who does all of my engine work, (I have 17 rental quads)
He mic-ed the pistons and found that there is no camber in the skirt. The skirt should be .007 to.010 narrower than the dome, he showed me this with a Wiesco, What he figures is happening is the side thrust is causing a problem.
When I explained this to the seller he said that the importer had just received a new/different batch of pistons from the factory.
Might have just been a bad batch.
#26
WOW.. guys you're making me worry.
I bought two of these Twister HammerHeads in June. I've only ran them about 10-15hrs. (at most) this summer. Although, very hard racing hours.. and the only problems I've had so far "knock on wood" is the bolts loosening. Hell I even rolled one upside down and rolled it back over and drove it back.
So far I've been impressed with them, but the only complaint would be the take off power.. you're not going to get a hole shot out of one of these stock. But then I have a 15y/o and hopefully he'll learn a lil' bit of driving technique and get the wild driving out on these and not on the street.
#27
#28
#29
#30
