Checking ignition timiing 84' 200es help
Hi, Now that the fossil is running i want to check the ignition timimg. Seems that it is missfiring alot on cold start, then only ocasionally when warmed up. May be timing or fuel setting. Can I hook up a induction timing light to it and check the timing?
thanks, |
I dont know if you cant read??? But this is the sxs section. Take it to the honda atv/atc section.
