Help, what trailer should I buy?
I have a Honda Rancher AT. I want a trailer that will hold just this quad. Needs to be just big enough to hold this quad.
I have a pickup with tool box and such. Needs to be just big enough to handle the Quad. I have limited space to store the trailer in my garage and will have to store the quad on it when not in use. Point me in the right direction. Thanks in advance |
Take a look at a 5' x 6' tilt bed. That should do the trick. dg
if space is an issue, harbor freight tool sells a bolt together trailer in sizes 4x 8 and 4x6.
when not in use it folds in half and tilts in a vertical position , then it can be placed against a garage wall or what not. it also has 2 sets of caster wheels so it can be wheeled around in its vertical position, they are under $300. it is NOT the most heavy duty trailer , but it qould works just great for a singel quad. if you go for this trailer , go with the biggest tire available for it. I think it is 12 or 13 inch. |
I had the same trailer that zsebi is talking about and I added some sides and was able to haul my King Quad and meat trailer, although I had to unhook the trailer and slide the tongue under the quad. I had both those with gear and three Caribou and the trailer handled fine even though I was way over the 900 hundred pound rating. For the money it is a great deal. I never folded it up as I have plenty of storage next to the shop. I bought mine from Fred Meyers for 199 on sale, that was 7 years ago. I bought a 8x10 tilt but now I have to get a four place trailer come spring when we add another quad to the family, I know that is not going to be cheap.AlaskaBoy.
