trx 125 smoking alot
Old Feb 18, 2004 | 12:08 PM
alpine8181's Avatar
Default trx 125 smoking alot
does anyone know what it could be this bike smokes non stop its a thick withe smoke and my mufler has like an oil film on it..thanks alpine..it is a trx 125
Old Feb 18, 2004 | 06:41 PM
440exhondasrock440ex's Avatar
top end needs rebuilt. its smokin cuz its burning oil
Old Feb 18, 2004 | 07:05 PM
alpine8181's Avatar
new rings?
Old Nov 16, 2007 | 06:09 PM
rpm9001's Avatar
Mine is doing the same thing exactly!! Did you ever find the problem? I just did a compression test 3 times and it was 120 psi. Let me know rpm90001@hotmail.com
Thanks
Old Nov 17, 2007 | 07:33 PM
rpm9001's Avatar
Anyone have any ideas?
Old Nov 17, 2007 | 08:27 PM
Gimpster's Avatar
Yes, the rings are probably bad, a stuck oil ring or a broken scraper ring. Other things that may cause it is a head gasket leaking from a oil gallery to the combustion chamber, or a loose/jumped timing chain causing unstable vacume during valve overlap sucking oil past the rings, or the piston skirts worn.
----- Gimpster -----
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
bvolks
Sep 13, 2015 12:57 PM
