ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   Rancher ES won't go in reverse? (https://atvconnection.com/forums/honda/146218-rancher-es-wont-go-reverse.html)
45acp Mar 28, 2004 12:13 AM
Before I make a trip to the Honda dealer I wanted to ask if anyone here has any ideas why my Rancher ES won't go in reverse. It was working fine until today. I push the reverse button down then pull the left hand brake lever and press the downshift button and nothing happens. No click and no reverse. The upshift and downshift buttons do work if I am going forward. I suspect something electronic has failed? If you have any ideas let me know. The failure is no big deal since the bike is still covered by warranty.
thanks,
45acp[img]i/expressions/face-icon-small-smile.gif[/img]
hondabuster Mar 28, 2004 12:59 AM
Could be the clutch needs adjustment.
BOWDEN Mar 28, 2004 01:15 AM
[img]i/expressions/face-icon-small-smile.gif[/img] CHECK TO MAKE SURE THAT 90 PERCENT OF THE SLACK IS OUT OF THE REV. CABLE YOU CAN ADJ. THIS ON THE ENGINE SIDE OF THE CABLE. THE CABLE CONNECTS TO THE REV. LEVER BETWEEN THE ENGINE AND SWINGARM YOU WILL SEE THE AJD. NUTS IF IT NEEDS ADJ. GOOD LUCK
ATVtech1 Mar 28, 2004 01:27 AM
Check on the lower rear of the engine (near the pull start) for an electrical connector that has come loose. This is the reverse switch connection and it is common for it to unplug (usually because of a branch); this will cause the exact problem you described.
300exRiderJay Mar 28, 2004 10:46 AM
It kinda looks like a mini spark plug cover and its under the quad.
45acp Mar 30, 2004 08:13 PM
ATVtech1 & 300EXRiderJay:
You were right on. The reverse switch connector was pulled off. I popped it back in place the and the quad shifts in reverse. Thanks again for your help. This saved me a trip to the dealership. Now back to riding and getting this baby broken in.
45acp [img]i/expressions/face-icon-small-happy.gif[/img]
ATVtech1 Mar 30, 2004 08:47 PM
Good going, I'm glad you found the problem, this is a fairly common thing. 300exRiderJay, I like your "mini spark plug cover" description, I'll use that in the future if you don't mind.
superlowgear Jul 9, 2004 01:17 AM
yup thats problably your problem my 350 es did the same thing
© 2026 MH Sub I, LLC dba Internet Brands
