Help on CDI's for a 400ex
I was looking at getting a cdi for my 400 but am not sure what to get... They have un-limited rev,and a extra 1,000 revs..I have the quad with a pipe,K&N,jetted,air box mod,....Tell me what worked for you!!!
I would stick with stock, there is no need for your engine to rev an extra 1,000RPM or more. When you hit the rev limiter you are done making power. The only possible time to consider getting an ignition is when you are running a race cam, otherwise you are just destroying your engine faster.
Thanks... What else can I do to make power with out getting into the motor?...
nutec or nitrous.
lot more strain on engine parts
Thanks... What else can I do to make power with out getting into the motor?... If you are looking to improve your speed on trails...you HAVE to upgrade your suspension before you even consider touching the engine. |
| All times are GMT -5. The time now is 01:59 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
