i know i have got to change my brake pads on the rear brakes of my recon
i was checking if i have to take off the right rear wheel, then open the case up and install it there? It seems like a good bit of work. just checking cuz im lazy |
ali, thats a good one...
I do believe the wheel has to come off.... hahha sorry man but I'm tickled. Sounds like something my son would say cuz he put the lay in lazy. Just sit them on top of the hub and let us know what happens. all in fun...later |
Hmm your lucky im here cause im doin the same all you do is take the right wheel off (when your looking at it from the back) then you have to take the axle nuts off then take apart the drum tehre just a couple of bolts around it then pop it of and then you can just pull the brakes out its not very hard at all the only problem i had was the axle nuts they are big ones lol that just sounds funny.. but i used a pipe wrench to get them off it worked :)
