2004 400ex is faster
Engine Type 397cc RFVC air-cooled dry-sump single-cylinder four-stroke "2003"
Bore and Stroke 85.0mm x 70.0mm
Carburetion 35.5mm piston-valve with accelerator pump
Ignition Solid-state CD with electronic advance
Starter Electric
DRIVE TRAIN
Clutch Manual
Transmission Five-speed
Driveline O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension Independent double-wishbone with Showa shocks, five-position spring-preload adjustability; 8.2-inch travel
Rear Suspension Pro-Link fully adjustable single Showa shock; 9.1-inch travel
Front Brakes Dual hydraulic 174mm discs
Rear Brake Single 220mm disc
Front Tires 22 x 7-10 knobby radial
Rear Tires 20 x 10-9 knobby radial
"2004"
Carburetion 38mm piston-valve with accelerator pump
Starter Electric
DRIVE TRAIN
Clutch Manual
Starter Electric
DRIVE TRAIN
Clutch Manual
"2004"
Starter Electric
DRIVE TRAIN
Clutch Manual
#15
#16
Originally posted by: Ish416
They didn't do anything to the 2004's. They are the exact same as the 99-03's. Yours might be faster because you have a fresh motor. There are no mechanical differences at all. The 38mm carb on the Honda website is a misprint.
#17
Originally posted by: cals400ex
yeah, but most still agree it is a misprint. i have called my local dealerships and had them check on it. after getting back with me they both told me it was the same carb as previous years. who knows......
#18
the 04 ds's are much faster than the previous years, and they shead like 20 pounds but it seems there's something in the engine, or the cdi that perked things up. and i wouldn't put it past honda to make a little change here and there to pass the others (suzuki) and not say a word. didn't i read the suzuki frame is almost the same as the 400ex frame just a mm here or there different. well i'm glad to hear the honda's are faster.
#19
#20
Lots' of times Honda and other OEM's will make small adjustments or improve a existing part that will radically improve a bikes performance with out changing the part number so as not to alarm the buyers. It can generate a recall or even worse hurt the residual sales of their ATVS.
