Does anyone know the web address of webcams or know the specs on the cam included
These are the specs on the hotcam.
Hot Cams Card
Part no:CRF450S2-A
Stage 2
Intake
Exhaust
Lift: 10.1mm
Lift: 8.7mm
Lobe Center: 109.75
Lobe Center: 105.5
Duration@1mm: 248
Duration@1mm: 268.5
Valve Lash: .15mm
Valve Lash: .28mm
Remarks: Timing and lift figures include no lash
Lash set cold
The stage 1 cam is the same on the exhaust, but smaller on the intake side at 9.6 lift and 237 duration.
I just got off the phone with Shawn at Hotcams and asked two questions.
1.Does the stock valve train need any upgrade for either cam? No.
2. Will I lose bottom end with the stage two? Once again he said no.
I'd like to contact webcam for their thoughts.....
Hot Cams Card
Part no:CRF450S2-A
Stage 2
Intake
Exhaust
Lift: 10.1mm
Lift: 8.7mm
Lobe Center: 109.75
Lobe Center: 105.5
Duration@1mm: 248
Duration@1mm: 268.5
Valve Lash: .15mm
Valve Lash: .28mm
Lash set cold
