400ex k&n air filter
Some people say you should re-jet if u put a k&n air filter on.do u have 2? how much extra horsepower will it add?
To me, it's not worth just doing a K&N without doing the header and muffler, and venting the airbox. I do know that if I slap a K&N on an otherwise stock 400EX, it will hardly run, which means you definitely need a rejet. So, it does something, but by itself it won't be dramatic.
i have just a kn and no airbox lid and it runs fine, no rejet needed
I dont wanna take off my airbox lid. Where i ride it would get very dirty. What about putting a k&n airbox lid. Would i still have to rejet?
Originally posted by: yellow400exman I dont wanna take off my airbox lid. Where i ride it would get very dirty. What about putting a k&n airbox lid. Would i still have to rejet? |
reconranger is right. You can't just put on an air filter and run good. Oh, it will run, but you aren't getting close to top performance. Especially if you take the airbox lid off. If you add a pipe, rejet, and add filter, you have the complete package. Each one complements the other.
think about it, your bike is jetted to run what the stock fuel flow is. If you push more air, you need to push more fuel. you accomplish this by running a bigger jet in the carb. I can run the bases with one shoe off and one shoe on, but when I put both my shoes on I run much faster and without a limp! |
Quote;i have just a kn and no airbox lid and it runs fine, no rejet needed .
The Honda 400EX comes from factory jetted on lean side for emmisions. Altitude and temperature are other factors that effect jetting. So for Tyson the only way his quote makes any sence would be if his riding area is at high altitude &/or hot temps. With his set up at sea level and cold temps he should have problems. Better to error on the rich side than take a chance damaging motor by running lean. I have this notion that in early stages of running lean the motor could be damaged before the rider has a clue from riding performance. |
So your saying that if we're in high altitude, then it would not matter about the lid being off or is it the whole filter in general? Right now we're in the mountains of Idaho about 30 miles from the Canadian border. But when we go home we have to go back to about almost 1000 feet in Washington. What would we ahve to do? I also asked the honda dealer if I would have to rejet it if I had just a filter and he said no, he said maybe if I had the filter and a slip on and definently if I had a full pipe and a filter. So how are you backin this situation up, just by your own knowledge? or by what other people are saying? Thanks
Ok.. I think i will wait till i get a pipe to re-jet. Thanks
there was a write a a couple years ago on pipes and jetting and how the manufactures spend a lot to get them very close to on then people change pipes and such and slowly get worse and worse. not all just the ones who don't know.
