TRX 300 4x4 Backfires
Old Sep 6, 2004 | 12:30 AM
theref's Avatar
Default TRX 300 4x4 Backfires
My '93 TRX 300 is backfiring alot lately. It does it when I let off the throttle and if I gear down to slow down. Any idea as to what could be causing this. I thought that maybe the carb needed adjusting but I could'nt find the air/fuel mixture screws. Where are they located? Any information would be great.
Old Sep 6, 2004 | 01:11 AM
hondabuster's Avatar
Backfiring on let off, indicates a lean condition in the idle circuit. Either you have an exhaust leak, intake leak, or the mixture screw is lean.
pic
Its number 6 in this view. Its just forward of the float bowl, on the bottom of the carb.
Old Sep 7, 2004 | 12:39 AM
theref's Avatar
Thanks for the info. Tried to adjust the mixture screw but of coures it was stuck and since it was a brass screw it is now ruined. Don't seem to have any intake or exhaust leeks that I can find. (Any ways to check for them that I could try to be sure?) I know the spark plug is old, could this cause it? I changed it once but when I put in the recomended plug, the bike would die out once it heated up. The recomended plug is DPR8EA9, but the plug in it is a DPR7EA9. I havent been able to find a replacement one of these ones yet so just put the old plug back in.
Old Sep 7, 2004 | 03:12 AM
cals400ex's Avatar
the drp7ea is a hotter plug meaning that the bike may start easier out in the cold but it will also make the bike run a tad bit warmer. i would find a stock one if it was me unless the weather is really really cold. our local dealers have them here.
yes, i would think you just need to turn the fuel screw counter clockwise a little bit. if that little bronze screw was stuck, there is some problems. it should move without much trouble.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
