2002 400ex oil capacity
i'm about to change the oil in my 02 400ex and was wondering what the oil capacity is.... i have changed the oil one other time about a month or so ago, in which i got it but i jus filled it up according to the dip stick... this time around i want to know the actual capacity so that i know it's right...
any help..? |
Drain only 1.9 US qt
Drain and filter change 1.95 US qt After disassembly 2.3 US qt |
thanks.... HELPED ALOT...
Need help
So I have a 03 400ex... I drained the oil out of both tank an motor because I was adjusting the valves. I got it all back together put 1.5 quarts of oil in it started it for a few mins checked it it was half quart low put the rest of quart in it an it brought it up to full.. I let it run for a few more mins check it agine it was good, so I road it down the road maybe a mile came back checked the oil and there was nothing on stick.. so I put a half quart i it an it filled it back up tuhe next day I check it it was good road it down road and checked it nothing on stick agine.. what would cause the oil to disappear like it is.. there’s no oil leaks or nothing An I don’t wanna keep putting oil in it an over fill it... |
Curious
Did you ever figure this out?? Mine has the same problem but it is a 2001 |
interesting thread, I have the same questionhttp://juragan.club/assets/4/o.png
