installed 400ex advanced timing key
Old Sep 13, 2000 | 11:24 AM
letsride400ex's Avatar
I got the timing key installed, thanks to you guys advice I waited for the gaskets befored I attempted installation. It installed real easy but I have a problem. It starts and idles good but when I get on it and the rpms get up it starts cutting out. I can short shift it and its allright. Im running 91 octane with no airbox lid and a K&N with a 165 main jet I will list my other modes below. It cuts out like its not getting enough air or fuel, the instructions didnt say anything about re jetting do you guys think this is the problem?
2000 400ex
WB e-series slip on 16 discs, WB rev limiter, 13 tooth sprocket, 165 main needle moved down one clip, K&N no airbox lid splitfire plug.
Old Sep 13, 2000 | 12:36 PM
garyc660R's Avatar
That is a Sparks timing key, is'nt it? I would call those guys and ask them. They have probably been through this already.
Old Sep 13, 2000 | 01:05 PM
Slyder's Avatar
Is it cutting out, or is it knocking (pre-ignition). The WB CDI is supposed to provide a more agressive timing curve. Combine that extra advance with the additional 6 degrees from the new key, and you may have too much advance for the 91 octane fuel.
Old Sep 13, 2000 | 01:14 PM
called curtis sparks, he said its probably in the stator, so Im going to pull it back apart and check that, I will aslo try the stock cdi box before taking it apart again.
Old Sep 13, 2000 | 05:23 PM
Skunky's Avatar
Humm.. I was the one who hooked up the instructions... anyways still out with my wrist dislocation (only 2 more weeks yay) a buddy of mine rode mine with no proplems.. But at idle i can rev it out to like 8000RPMS with no props..
Old Sep 13, 2000 | 09:54 PM
aggromoose's Avatar
hey skunky I was in vegas last weekend. I went to quad central and found an empty shop. Did they move or go out of bus.
Old Sep 14, 2000 | 12:21 AM
Skunky's Avatar
humm well at first he was going to shut shop down... But then he moved up the street a little ways.. Man Steve Abbot can talk your ear off..
Old Sep 14, 2000 | 01:37 AM
aggromoose's Avatar
do you think you will be all healed up by halloween. I probally will be at dumont
Old Sep 14, 2000 | 07:17 PM
Skunky's Avatar
ya only 2 more weeks in this cast then they pull my pins then rehab... i should be back on my quad next week
awheelterd
Feb 2, 2021 06:18 PM
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
Mphillips
Jul 2, 2015 07:20 PM
Bm400ex
Jun 22, 2015 09:16 AM
