250r idleing
i cant seem to get the R to idle without giving it some gas because if i dont give it gas it will stall. what should i do to adjust the idle??
250r idleing
isn't there a trottle adjustment screw somewhere on the carb or throttle cable?
250r idleing
Originally posted by: LittleBill isn't there a trottle adjustment screw somewhere on the carb or throttle cable? |
250r idleing
i was playing with that but it didnt seem to work ill try again anything else i can do??
250r idleing
CHeck your throttle cable. You may have to adjust the cable.
250r idleing
If thats not working your carb may be dirty. Clean it with carb cleaner then blow it out with compressed air. Worked for me when I had this problem 2 weeks ago.
250r idleing
i think the throttle cable is streched because there is some slack when i took the cover off the throttle box on the bars. do i need to buy a new one?
250r idleing
Try droping your pilot jet down one size. The throttle wont make a diffrence in idleing unless it has NO slack, so your ok with that.
