450es display has 2 dashes for gear..wont start
Old Jul 19, 2005 | 01:39 AM
REDWING's Avatar
Default 450es display has 2 dashes for gear..wont start
I have a 450es Foreman 2000 model..turn the key, display comes on, for the gear it shows 2 dashes?? it will not start...tried disconnecting and reconnecting batt...tried charging batt....I had just started it and rode for about 1 min, was in 2nd gear and the display for the gear position went to 2 dashes...stopped turned off and that was it...any thoughts???
Old Jul 19, 2005 | 02:05 AM
hondabuster's Avatar
The reason it wont start, is because its stiil in gear, and theres no nuetral light. Use the handle, on the stub shift shaft, and put it in nuetral, and try again. Cycleing the key to off, and back on, should clear the problem. If it doesnt, keep posting.
Welcome to the forums.
Old Jul 20, 2005 | 01:46 AM
REDWING's Avatar
What you do here..helping people fix there stuff is really a good thing...thank you for your time and advice..it worked..again thank you..Redwing
Old Jul 20, 2005 | 02:01 PM
Sometimes thats all thats needed. But if it keeps doing it, often, post back.
Thanks for the compliment
whitty
67
Feb 24, 2021 02:52 PM
Mattius
Jul 11, 2015 10:44 PM
1000gade
May 27, 2015 12:37 PM
CanadianViking
Feb 16, 2001 11:56 AM
JRM
Jul 29, 2000 01:58 PM
