ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   Recon, Doesn't shift. Just blinks on 1rst (https://atvconnection.com/forums/honda/214466-recon-doesnt-shift-just-blinks-1rst.html)
Dansrecon Aug 23, 2005 02:15 PM
I am new to this forum,
03 Honda Recon
Does anyone know how to fix this problem ? The ATV doesn't shift & the 1rst gear light just blinks,
I was reading about some else here that had a similar issue, but I never read if he fixed the problem.
Any help would be great !
hondabuster Aug 23, 2005 03:17 PM
Use the manual handle to shift it back into nuetral. Then go key off, and key back on. Does it still flash? how many times?
Dansrecon Aug 23, 2005 03:28 PM
Thanks , I will try this ..And let you know,
P.s..where is the manual shift ?
quicksilver Aug 24, 2005 12:10 AM
if you look on the left side of the engine just below the foot guard, there is a hexagonal shaft sticking out about an inch. thats the emergency shift thingy. If you look in the back trunk thing, where the tool kit is stored, you will find a metal lever with a hexagonal hole in it that fits on that shaft and extends out so you can kick it with your foot.
rotating backwards is shift up, forwards is shift down. Dont overwork it, it's not good for the shift motor to be moving it around, but it works for emergencies.
sounds like you got something wrong tho, dont think that just putting it in neutral is gonna fix anything.
Dansrecon Aug 24, 2005 12:19 PM
There is something wrong,
I started it up last night & it worked, then..it didn't, weird..
It needs a new battery, I'm gonna start with replacing the battery & give it a tune up & clean everything I possibly can. If it still is acting up , I think I'm gonna bring it in to the proffessionals...
ixRAZORxi Aug 24, 2005 12:34 PM
Es will not work if the battery is disconnected or if it has a bad cell. It has to make a complete circuit or es will not work.
My positive wire broke on me once and i couldn't shift until I spliced it back togheter in the woods.
Dansrecon Aug 24, 2005 12:45 PM
My ride is actually a 2001 & I have never replaced the battery, I think that is the major problem.
Thanks for the advice
hondabuster Aug 24, 2005 02:18 PM
If its a 2001, then it wont flash a code. Youll need a clymers manual or honda service manual, to troubleshoot the problem. Going to nuetral and going key off and key on, will clear whatever the code was, but if theres still a problem, itll just come back.
Its posible that replacing the battery will fix it, and if it doesnt , then do the clutch adjustment, and if you want to do the work, youll need a manual, or someone to step you through the voltage and resistance checks. Its not that hard to do, but youll need a voltohmmeter and know how to use it.
Lighthouse Aug 24, 2005 10:41 PM
Check back a few pages and look for recon shifting problems all the answers are there for what the problem could be
John
© 2026 MH Sub I, LLC dba Internet Brands
