ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   My Honda 400ex won't start, help (https://atvconnection.com/forums/honda/234203-my-honda-400ex-wont-start-help.html)
Remito Mar 19, 2006 05:19 PM
the quad has been in the garage for three months, I tried to started, the battery is good, the starter turns, but it wont fire up. what could it be
TractorPacker Mar 19, 2006 05:42 PM
A new spark plug, and it will most likely start right up.
Remito Mar 19, 2006 06:46 PM
thank you Tractor, I will go and purchase one tomorrow, all shops are closed today
LittleBill Mar 19, 2006 10:01 PM
bet ya five bucks that won't do crap, prolly fuel related if u don't have ur kill switch on or something
monster88 Mar 20, 2006 08:02 AM
it may be the plug... I tried starting mine for days. Took out the plug and it was that.
Remito Mar 21, 2006 10:57 PM
I went and bought the plug and the tool to remove it, well the tool did not fit, i got to go back tomorrow.
TractorPacker Mar 21, 2006 11:05 PM
I see in your signature that you have a 400ex, it makes me want to believe you.
Andy14225 Mar 26, 2006 03:48 PM
I have the same problem. I put my 400ex in the garage for a few months(removeing the battery) and went to start it today. Surprise Surprise it wouldn't start. Every-thing sounds good the motor just won't kick. When I put it away for the winter every-thing ran and opperated fine considering i've only had it for 6 months. Any Ideas? besides the spark plug
Gimpster Mar 26, 2006 05:51 PM
If there was fuel in the carb bowl when you parked the unit, it has lost its volitility. If an attempt is made to start the unit after that period of setting with the fuel in the bowl, it will foul the spark plug because the fuel will not burn. It will continue to foul spark plugs until enough fresh fuel is replantished in the carb bowl.
Turn off the fuel valve. Drain the carb by opening the fuel drain screw on the bottom side of the float bowl. Add some fresh fuel to the tank, replace the spark plug, turn the fuel valve back on. The ATV should start. If it does start and will not idle, most likely the slow jet circut is plugged. Over time with stale gas in the bowl, It will gell or oxidize and plug the jets.
If your unit will not be run for a while, turn off the fuel and drain the carb. Add some fuel stabilizer to the fuel tank. I prefer Sea Foam. When the unit is to be used again, simply turn the fuel valve back on and start-up should not be a problem.
----- Gimpster -----
Andy14225 Mar 26, 2006 09:46 PM
Thanx!! but when i stored it i made sure there was no gas in the tank. It was bone dry when i pulled it out. So i don't kno
© 2026 MH Sub I, LLC dba Internet Brands
