185s won't start
My first bike , been riding it for a few months always ran fine. One day I loaded it
into truck , started it revved it a few times , then drove truck to beach , unloaded it and won't start. Tried to push start and nothing. Acts like electrical problem. Has small spark when I pull the cord with screwdriver to wire. I need to know what would be the first things to check. Any help appreciated Thanks |
185s won't start
Electrical parts are not going to go bad between the time it was last run and when trying to restart later. It's just something that very rarely happens with any ATVs electrical parts.
It sounds to me as if you simply fouled the plug when you tried restarting it because earlier you had revved it cold and then killed it. |
185s won't start
First, electrical parts CAN go bad between trips. Not likely, but possible epecially if you drop the bike off the tailgate. Start with the plug replacement. Don't check spark with a screwdriver. Use another spark plug, attach plug to wire and lay it against the head away from the hole.
Most likely your prob is flooded motor. Drain the float bowl and replace the plug. Sometimes the needle in the carb gets stuck. It's the lower most flathead screw on the carb. |
185s won't start
Thanks bro , you were right on about the 185s. Got it going today with a new
spark plug , I appreciate you responding. |
| All times are GMT -5. The time now is 03:14 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
