250 Recon ES Shifting Problem
Just a heads up though, rear of the engine there is a plate covering the reverse cable pivot. Under that cover is a reverse switch also. Just for kicks you should try grounding the wire going to the sender when the issue is occoring. The switch may still be bad. It does need the speed sensor though. I have had a number of speed sensor failures on recons and it causes all kinds of driveability problems one wouldn't think is affiliated to it
----- Gimpster -----
