Honda 185s
Hey guys I have a honda 185s bored .15 over and I just recently got a new top end kit and it has been running good but still smoking. Anyway when I go and check the oil it says full then I let it run for a bit then it says half full then I shut it off then it says empty and then repeat that whole prosses over again why is it doing this I just dont want my motor to lock up over a dip stick. Also why dose it use so much oil.
ANY HELP WILL BE APPRICIATED THANK YOU! |
Honda 185s
Smoking??
cylinder honed/right? ring gaps spaced right? ring busted while assembling? piston not right size for cyl? valve guides wore out? crankcase breather open? Ron |
