2005 Rancher AT won't shift
My 2005 Rancher AT will not change gears. It will change from D to N to R, but when in Drive, it is locked in low gear. Doesn't matter if it is in ESP or Auto. Engine starts and runs fine in Drive. Also, when I shift into reverse, it doesn't want to run very well, starts sputtering and has very little power. This all started happening shortly after I drove through a creek, but I have driven through the same creek dozens of times. It only has about 1100 miles on it. Any help will be greatly appreciated. Thanks!
The gear position indicator should be flashing , you have to count the flashes..
There are 5 flashes.
Code #5 is angle sensor "motor lock".. First check the couplers for the angle sensor & shift control motor for water/moisture .. Here are the tests ..
================================================== ================================================== ===================== https://img201.imageshack.us/img201/72/400code51wk2.jpg https://img228.imageshack.us/img228/...0code52zj0.jpg https://img442.imageshack.us/img442/...0code53tt1.jpg https://img402.imageshack.us/img402/...0code54tt9.jpg https://img442.imageshack.us/img442/...0code55rv2.jpg https://img228.imageshack.us/img228/...0code56dz5.jpg |
Thanks for the info and diagrams. I will check it out this weekend, and get back with you. Can't thank you enough!
| All times are GMT -5. The time now is 01:35 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
