Question About My 1987 250x
I bought my buddies 250x. It has been sitting for about two years. It ran whenever he put it up. But, for some reason it won't crank. Its kick start. I changed the oil, put a new spark plug in it, and put new gas in it.
Does anyone have any suggestions or tips or Somethin! Thanks |
you probally need to remove and clean the carb...the jets are most likley stopped up from old gas were it sat up...thats what i had to do to get mine running from sitting up a couple years
if that dosent work ...check for spark ..you may need to clean the stator and fly wheel but if you have a blue spark its exelent a yellow spark may indicate a weak spark also if no spark check all youre wire connections ussaly you can simply un plug and replug them in .......if your gas tank is rusty put a inline fuel filter between it and the carb ,or replace the tank
