WHAT IS THE BEST KIND OF BORE KIT FOR MY 05' 400EX
je makes a great piston for the 400ex and any other engine! weisco is bottom line and the cheepest, but will do fine for a 400! if you want performance and quality check out cp pistons! there the best ever, and not just my opinion. check the web site!
weisco is a great piston. just bottom line. its like...mcdonalds has great burgers, but youll get a better one at a steak house. question was what do i have... i run CP pistons in everything i own!!!! for instance, you can get a complete weisco set ( piston, rings, gaskets, and o rings ) for $89.00! go to CP, you can get custom pistons made just 4 your bike! ceramic coating below the rings, and kevlar top to prevent pre ignition spark damage!! but is gonna be anywhere from $200.00 and more just for the piston. there x forged for stability! they are lightr that any piston. there is just so much to learn about them. besides...you get what u pay for and the piston takes more wear than any other thing in the engine!!
check em out at CP racing
CP Pistons offers over 120 shelf part pistons featuring Honda, Yamaha, Suzuki, Kawasaki, KTM and others for your street or powersports application. Each of these pistons was designed through extensive research and development with the cooperation of some of the biggest names in motorsports. These pistons are available in standard size or big bore kits and are compatible with higher lift cams and oversize valves. Each of these pistons incorporates an "X" style forging for addition strength, durability and weight reduction. Along with the our standard aftermarket pistons, CP offers full race pistons for certain applications. These are custom pistons that are available on the shelf. The race pistons are a lightweight, high compression version that comes standard with skirt coating and gas ports. All of our pistons represent the highest quality and are engineered for maximum power.
CP offers a wide variety of forgings made specifically for you application. Each piston is designed using sophisticated 3-D modeling software and manufactured with advanced 5-axis techniques making you piston the lightest and strongest piston on the market. See custom piston section for more details.
Shelf part features include
Double forced pin oilers Fully CNC machined
Accumulator Grooves Pick-lock grooves
Anti-Detonation Grooves X style forgings
CPW Lightweight pins High performance rings
Millenium oversize cylinders are available for certain applications. See cylinder chapter under catalog section for more information.
Cometic gasket kits are available for all shelf parts. See gasket chapter under catalog section for more information. Gasket kits are listed in the catalog to correspond with your application.
Quadzilla Heritage
09-25-2015 01:39 PM
