ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   Engine won't turn (https://atvconnection.com/forums/honda/304769-engine-wont-turn.html)
freeURman Jan 10, 2009 12:17 PM
Engine won't turn
450 foreman won't turn over. Thought originally it had siezed up. It will turn fine without the spark plug. So i took a look at the valves. No damage there. After adjusting the valves it started to turn. Turned over but wouldn't run without the choke pulled fully. Smoked like crazy. After about a minute of trying to start it siezed back up. Is the timing chain stretched?
cherokee99 Jan 10, 2009 07:39 PM
Engine won't turn
if its been sitting you may have no lubrication, and if you have to use full choke its likely the carb needs cleaned
JeffinTD Jan 10, 2009 11:46 PM
Engine won't turn
Could the cylinder be full of water, or say gas from an overflowing carb?
Liquid won't compress, so if there is some in the cylinder, that would cause the motor to lock, but turn freely if the spark plug was removed...
freeURman Jan 11, 2009 05:49 PM
Engine won't turn
I messed with the valves some more and got it running. Smokes really bad and sprays oil out the exhaust. I guess those valves weren't ok after all. I'm gonna rebuild the top end
BlueRubie Jan 12, 2009 04:38 AM
Engine won't turn
O boy. . . Sounds like sombody cranked the valves down to try for a better seal. . . rebuilding the head won't do you much good if shes throwing oil out the exhaust. . .
Time for a Jug n Piston assembly. . .
1. Piston.
2. Rings.
3. cylinder.
4. Feul Filter.
5.Carb kit.
6. Spark plug.
replace these i bet it run perfectly. . .
Mikey !
freeURman Jan 18, 2009 05:03 PM
Engine won't turn
There's discoloration up the exhaust valve. Is it possible the oil out of the exhaust is getting in past the stem seal. There's still good compression and no marks on the cylinder wall
JeffinTD Jan 18, 2009 07:11 PM
Engine won't turn
Stem seals can leak oil.
© 2026 MH Sub I, LLC dba Internet Brands
