05 honda recon 250 2x4 maintenance HELP!
im doing maintenance on my 05 honda recon 2x4. i have done maintenance on other quads before, so i just need to know what oils and stuff i need. keep in mind that i am in central florida and it will be in the 90*-100*F range over the summer. what oil weight and type will i need? what oil filter will i need? what oil will i need for the rear gearcase? is there anything else i need? any help is appreciated, thanks!
Again...don't be a cheapo....go get yourself an owner's manual, and better yet a service manual as well.
http://forums.atvconnection.co...tid/8/threadid/561544
Pretty much the same, except the Recon has no oil filter. It does however have a very effective centrifugal filter that needs to be serviced every 200 hours or so.
Again....don't neglect valve adjustments!
Thanks, 09 Recon
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
05, 250, atv, es, filter, honda, maintainence, maintenance, oil, recn, recommendation, recon, settings, specs, valve
