Honda 420 (2x4) EFI
Old 11-26-2009, 10:45 AM
JYounts's Avatar
Default Honda 420 (2x4) EFI
I have a 2007 Honda Racher and after a recent day of riding I loaded my atv up on the trailer and brought it home. When I went to take it off of the trailer the idle was extremley high and will not come down. Any advice on how to fix this problem? Thanks in advance.
Old 11-26-2009, 11:21 AM
xtc's Avatar
xtc
xtc is offline
Have you tryed to adjust the idle screw on the carb?
It is the larger screw toward the top of the carb,it usually doesn't turn on its own but maybe it is loose.
Turn counter clockwise to lower idle,turn only 1/4" at a time and let it sit and adjust until you get it back to norm.
Also,choke cable not stuch is it?
Hope this helps
Old 11-26-2009, 01:01 PM
Tom of Barbaria's Avatar
One a Rancher 420 there is no carb its a fuel injected atv, nor is there a choke cable. there is a way to adjust the idle i have read on here how to do this, Reconranger and Honda Mechanic would be the ones to ask
Old 11-26-2009, 01:14 PM
xtc's Avatar
xtc
xtc is offline
My bad,guess I should have read the capation more closely,was thinking about my buddies 350 rancher....sorry
Old 12-19-2009, 08:19 AM
JeffinTD's Avatar
The rancher has an idle air controller. It is on top of the throttle body, blk plastic, held by a rectangular shaped metal piece and two tamper resistant torx screws.
Remove it, and hit it with carb cleaner, screw it back together, and put it back on.
Old 04-23-2011, 12:57 PM
100Proof's Avatar
This worked for me today. Thanks for the help!
100 Proof
wendal
10-31-2017 03:31 AM
rgjackson
09-17-2015 11:21 AM
wendal
09-15-2015 01:50 PM
wendal
09-15-2015 01:48 PM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: Honda 420 (2x4) EFI
