Challenging Question here...
#21
Follow The shaft Back to the rear From where you had the screw driver poking at the boot to where it goes in the engine or transmission. Take that cover off.
You will find your problem right there un less you have tranny gear damage.
The differentul looked ok as when you turned the wheel one wheel spun one direction one spun the oppisite direction.
#24
what's the differential? where the drive shaft turns towards the tires?
#25
So I have eliminated these two areas as there is no movement when turning the front tires while in gear, so what you are telling me is that it may be these other two spline areas or the differential that I have circled?
