No front wheel drive Honda foreman
Hi, I have an older foreman probably late 90's early 2000.
The kids were using it last week, now I have no drive to the front. Is there an electrical switch like the reverse, a manual lever, or am I talking internal tranny problems that transfer power to the front. It does not appear as if the front drive shaft is turning from the tranny end. Any suggestions Regards Ted |
May have stripped the splines on the driveshaft. You may have to pull the front differential and driveshaft and check them.
Originally Posted by Helmut1
(Post 2886350)
I have brought it indoors, thinking the same after I posed Ted |
Dirt gets in and wears the splines on both the drive shaft and the drive shaft joint .. This is a picture of the parts to check ..
============================================= http://img34.imageshack.us/img34/9514/450diff.jpg |
Originally Posted by HondaMechanic
(Post 2886531)
============================================= http://img34.imageshack.us/img34/9514/450diff.jpg too good dude ........ it helps me a lot ........ |
Thanx for pick on the front housing.
I had another problem come up so I cannot get to this until Thursday evening. I think you guys have given me enough to keep me busy. I do hae a feeling it is going be up in the front end, or the dirt in the splines. Regards And thanks for the help Ted |
