ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   Starter won't stop turning over (https://atvconnection.com/forums/honda/328498-starter-wont-stop-turning-over.html)
moretti Jun 29, 2010 02:43 AM
The starter on my Honda 300 Fourtrax continues to stay engaged even after I have released the starter button, turned off the kill switch, and turned off the ignition key. I put in a new starter, new solenoid, new neutral switch, and a new battery, but still have the problem. The only way I can get the starter to stop turning is to disconnect the ground terminal from the battery. Does anyone have any ideas what the problem could be?
fourtraxhonda300 Jun 29, 2010 06:20 AM
sounds to me like your ground wire, coming from the starter is getting grounded out agianst the frame. look for naked spots on it.
papa hogg scoot Jun 29, 2010 06:26 AM
Its sounds like you have put alot of parts on it already.IMO the starter clucth is staying engaged that behind the flywheel. its an one way bearing that free wheel when engine is running and lock in engage when engine stops, this alouds the gears to be in right location to start when engine starter button is push to stsrt.
papa hogg scoot Jun 29, 2010 07:03 AM
Also if you think its is electical i would double check your starter wire and batt pos wire .it is very easy to get the two wires crossed up when installing starter . check wires from soleniod to starter make sure starter wire runs to soleniod on one side [big wire]and batt.pos to the other side, these wires looks the same but not and easy to install wrong.
budedm Jun 29, 2010 07:23 AM
Maybe the starter button itself is bad.
moretti Jun 29, 2010 10:28 AM
Hey: Fourtrax Honda 300
I think you may be right about the starter wire grounding against the frame, but why does it matter? Isn't the motor attached to the frame anyway and therefore already grounded against the frame.
fourtraxhonda300 Jul 1, 2010 12:17 AM
what makes starters work, is a celenoid, which makes a complete circuit, if the hot wire touches the frame, then that makes a complete circuit also. causing the starter to crank, non stop. (sorry about saying ground wire on my other post). got mixed up. lol
© 2026 MH Sub I, LLC dba Internet Brands
