What's this? (400ex carb)
1 Attachment(s)
I bought an 07 400ex (upgraded from my 01 300ex) and I'm getting ready to tear into my carb and I noticed this hose sticking out and not going anywhere. Is it just a vent? My first thought was a vacuum line for the petcock, but then I saw that it is not a vacuum operated petcock. I see on it's located in a place unusual for vacuum so I started it to see if it was. As expected, it's not vacuum. What does it go to? If it is just a vent, where does it lay? Thanks in advance!
Attachment 18264 |
Originally Posted by rich1340
(Post 2977872)
http://i1034.photobucket.com/albums/...117_194051.jpg Look for another hose hooked to the bottom of the carb bowl , if there isn't one on the bottom ; then it has to be for the carb vent/overflow . Good luck to you and welcome to the forum ! williebee..... |
if you lift up that rubber pad i think it has a hole in the frame tube right there it gos down in.
it goes right on top through the black rubber peice with the other hose
| All times are GMT -5. The time now is 09:52 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
