2001 Honda foreman 450 es shift problems
hey guys i need some help i was givin a honda foreman 450 es by my aunt got it running and know i am tryin to get the es to work and replaced everything i can think of and it still doesn't want to work i can't figure out what it is when i turn on the key i can hear a relay clicking ive gone over all the wiring and cant find the problem so if you can please give me a hand. thanks.
Please briefy list what you have replaced?
shift motor, angle sensor, battery, and the controls on the handle bars
Thanks..Will it hand shift manually with shift tool?Did you clean the 2 gears behind the shift motor?
yes and yes i think it is the ecu
Just for grins did you check charging system? Possible if system not getting enough volts when running the esp may not work correct...
yea its workin fine
