ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   400EX won't start (https://atvconnection.com/forums/honda/348555-400ex-wont-start.html)
400EXrider02 Jan 9, 2013 09:16 PM
400EX won't start
So recently I put a new headlight switch on mine which includes the starter button, high/lo beams, and kill switch. I went splashing around in some water earlier so am not sure if that did it or what? I don't see why it would, aren't these things made to splash through puddles? Now it wont start or anything, turn the key on, lights don't come on, and the starter switch wont do a thing. What the heck is wrong? Really starting to think this thing is determined to nickel and dime me to death...It's a 2002 400EX if that helps, thanks!
papa hogg scoot Jan 9, 2013 10:34 PM
The switch in these atvs are pretty simple....I would double check to see if it came unplugged first. Then check the main fuse....And get back here with us..Good Luck
400EXrider02 Jan 9, 2013 11:01 PM
THey are all plugged in, where would I find the main fuse?
Paulie_Cicero Jan 9, 2013 11:10 PM
Maybe a wire on the back of the ignition itself is/was corroded, and simply came apart. Also, If you turn the ignition on, and you get nothing, Like you said. It sounds like a bad fuse, or maybe a bad starter solenoid, Loose Battery Cable ??
Let The Fun Begin......LOL
Paulie_Cicero Jan 9, 2013 11:20 PM
As Far As Locating The Fuses, Check Near The Battery, Or Under The Seat. Maybe under the front hood, that houses the headlights, underneath the handlebars. They put them in the darndest places... Damm Engineers. LOL
Good Luck To You Bro.........
© 2026 MH Sub I, LLC dba Internet Brands
