HELP!!! Honda Foreman S won't down shift
2002 honda foreman s won't Down shift into neutral. Any advice would be GREATLY appreciated.
Not sure what that S stands for, ES is electric shift, faults on an ES are a whole different ball game to those on a foot change Foreman.
S is just the Standard foot Shift. Usually the E.S thumb shift get all the problems.
Troy is correct it's a standard foot shift. I can't find any information on this issue anywhere.Am I the only one who ran into this.Any info anyone could offer would be greatly appreciated. I'm desperate.
Selector problems are quite common, usually on 350s. The clutch cover has to come off and the gearchange mechanism checked for cracks, also the star wheel can come loose, I always Loctite the little screw in the centre when re-fitting it. Both clutches have to come off to get at some parts of the selector mechanism.
Thank you merry man,can you tell me do I have to remove the engine from the atv to check theses parts
No, I stand the quad on it's backside, remove the front footwell plastics and the black ones under the front wheelarches. I don't think you need to remove the prop shaft on a 450, (you do on a 350) but if you do, the diff has to be loosened and moved forwards. The clutch cover can then be removed, watch out for a loose washer. The clutch lifter doesn't cause problems but the other selector levers and pawls can crack or bits break off, some you can see without removing the clutches, and some you can't.
Merryman thank you,You have been very helpful. I used my atv for some chores around the house and it didn't get stuck in 1st but it feels very hard to shift it's not as smooth as it use to be. Does this help in the diagnosing process????
May try clutch adjustment first. before you remove front engine case cover
Help
Originally Posted by papa hogg scoot
(Post 3249826)
| All times are GMT -5. The time now is 03:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
