2001Honda Foreman Rubicon
It's me again. Got problems somewhere. My rubicon runs fine ideling. When I hold the engine revved up for about a minute and let off throttle it dies. Same way running down the road when I run it up fast and let off the throttle it dies. It has a hesitation when I first start off that also kills the engine. I mess around the the choke and it starts back up, but still does the same thing. Filter is clean, tried different plugs no change. Carburetor looks clean inside, but I know that don't mean it's any good. Hoping there a fix cheaper than the carb. It will set and idle all day. When it's warmed up and I pull the choke out it doesn't kill the motor, it just gives it a hi idle. Need help. Got someone coming to buy it tomorrow, but if I can't get it fixed, I wouldn't sell anything not running right. Thank you and Gods blessings to all.
Here is not a bad video on cleaning the carb in case it is helpful. Do not think jets are that expensive either, last ones I bought cost $7 a jet cdn but that was 20 years ago.
