2003 Honda Foreman 450es
Old 05-10-2017, 03:49 PM
Catray12's Avatar
Default 2003 Honda Foreman 450es
i will not shift into revers. all other gears are fine. just will not go into reverse. bought a new battery, changed angle sensor
Old 05-10-2017, 09:03 PM
papa hogg scoot's Avatar
Maybe gear shift switch in back of engine need to run ohms test I guess an see what switch is doing? Does speedo work?
Old 05-10-2017, 09:05 PM
Welcome aboard
Old 05-11-2017, 02:41 AM
You have to press the red button and pull on the left handbrake, I assume you know this, but if you have overdone the adjustment on that brake, the lever may not be going back far enough to allow reverse to be selected. On an ES there is also a switch inside the gearbox that stops the ES button from working until the lever at the bottom end of the reverse lock out cable has moved far enough, so it won't even try if you are not pulling the handbrake far enough back. There is a cable adjuster on the reverse lock out cable.
Old 05-26-2017, 01:29 PM
Catray12's Avatar
THANK YOU SO MUCH FOR YOUR IDEALS!! i have ran out!! I am such a Newbie Thank You for you time!!! Speed is fine, everything is except NO Reverse! I am so proud my Ex-Husband broke it. Please help me fix it, lol The men in my neighborhood are impressed that I have it tore down, and I am sure laughing at me at the same time, but they say good Luck we can't help you get it back together. Too stubborn to give up now.. I have change changed Angle Sensor, Oil, Air Filters, Oil Filters, New Battery. A Lady at the local Honda Shop was so bad to me for even trying to buy Oil and Filters, She said if I worked on it not to Call them for help later. Tried to give me the wrong amount of Oil to put back in it, Another guy from behind the counter had to come up and help. Thanks So Much for at least your kindness!! I tested the Gear Shift Switch, haha but maybe should do it again since my skills are growing, lol I also will go tighten the handbrake. Driving me crazy, up late last night trying to figure out what to try next, noticed brake line looked really loose, could be I loosen it??? THANK YOU AGAIN!! I have been riding it for years and clear snow with it in the Winters, now its time to learn to work on it
Old 05-26-2017, 01:33 PM
Catray12's Avatar
I download a Manuel and printed it out! really trying! Dumb Girl has hit very hard, lol
Old 05-26-2017, 01:34 PM
Catray12's Avatar
Bye the way Whole New Respect For You Guys!!!
Jared Washington
10-12-2016 12:05 PM
ThatLambethDude
08-01-2016 06:42 PM
lovinhonda
01-25-2000 09:17 PM
clayman
01-25-2000 05:57 PM
Quick Reply: 2003 Honda Foreman 450es
