2000 Rancher ES Blowes main fuse - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 09-21-2017, 04:44 PM
Default 2000 Rancher ES Blowes main fuse
New here and can use some help. Neighbor has a 2000 Rancher ES blows main fuse with key off. Problem started when riding, just died, found blown fuse. Rigged up test light to each side of main fuse spades. The only way the light will go out is to disconnect the dash, rectifier and key switch. What do these three things have in common. Or does he have 3 different problems. Limited tools, working at the deer camp.
Old 09-22-2017, 02:10 AM
I know you have checked it, but if the fuse blows when the ignition is off, it is always the regulator. Disconnect that, re-connect the ignition and dash and see if the fuse still blows, my guess is that it won't.
Old 09-22-2017, 05:09 AM
Thanks fot the quick reply. That's one of the three components (RECTIFIER, REGULATOR) that I have unplugged for the fuse not to blow. The thing is I need all three for the fuse not to blow.
Old 09-22-2017, 08:59 AM
Ordered a regulator/rectifier. Will swap this out and keep going. The regulator/rectifier looks damaged near the mounting bolts
Old 09-25-2017, 06:33 PM
Installed the new rectifier, that's not the problem. Started going through the harness looking for bad wires, no luck yet. I have checked about 1/3 of the harness so far. Don't know what I moved but now the 30amp engine fuse now blows with the key off.
Old 09-26-2017, 02:39 AM
If the fuse blows with the key off, the fault is in the wires between main fuse and ignition switch. All that is in that circuit is the regulator, so if the regulator is OK, a red wire from main fuse to regulator or to ignition switch has shorted out, or the switch has shorted internally. Unplug the switch and check if the fault is still on. If it is, check those two red wires all the way from main fuse to regulator to switch. As it is a short to earth, it is less likely to be inside the loom, so check where the red is visible first.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
