1996 TRX300EX with kickstart only??
Old 02-25-2019, 01:31 PM
shwthomas1975's Avatar
Default 1996 TRX300EX with kickstart only??
Hello. I just picked up a used 96 300EX in a package deal and it has a kickstart. No button for electric start. I thought these were all electric starts?
Am I wrong?
thanx for your time.
Old 03-01-2019, 08:58 PM
Lt Granddad's Avatar
I thought when they went from the 250x to 300 ex they were all electric start. That should be what the e In ex stands for. Kinda like the trx450, 04/05 were kick start 06 they added es to the name for the electric start. Somebody probably changed it to kickstart or you have an older 250x motor which is same bore as 300 ex with shorter stroke and kickstart. Somewhere on motor it’ll say 246cc or 282cc to identify which.
Old 03-01-2019, 09:23 PM
Thank you. Great information. I’ll check around on the motor tomorrow and see what it says. The vin on the frame says it’s a 300EX. But even the plastics have a spot where the the kickstart rests.
Just kind of odd. Lol.
Thanks again.
Old 03-02-2019, 02:43 PM
LT80's Avatar
LT80 Expert
I'd bet it's a 250x motor. To put a kicker on a 300ex motor can be done but it's a big job cuz the kicker goes in when the motor is split in 1/2. I have yet to see anyone waste their time doing so.
Old 03-02-2019, 02:56 PM
They may have used the rear plastic from a 250x it has the kickstart spot in plastic . Not sure if you could buy 300ex aftermarket plastic with with kickstart groove in it.
edin351
07-29-2010 11:14 PM
psi3000
09-09-2008 03:24 PM
MudRider
03-22-2000 06:23 PM
400exalltheway
03-21-2000 05:01 PM
SuperSwamper00
03-07-2000 07:29 PM
Quick Reply: 1996 TRX300EX with kickstart only??
