400ex throttle adj
To make sure the throttle is opening all the way, you can do this:
Remove the air boot from the carb. Look inside the carb, make sure the slide that goes up and down is completely out of view when at full throttle.
To adjust if need be, pull back rubber boot on throttle cable at the thumb throttle. Loosen lock nut, turn cable counter clock wise til you have no less than 1/8" play in thumb throttle. Tighten lock nut.
You're done.
If this is too confusing, e-mail me and I'll try to clear it up.
Good luck..ours were adjusted OK.
Later....Sher
You're done.
Later....Sher
MeadowlarkFarm
Nov 27, 2019 08:40 PM
