Im wondering if anyone here has done compression test on 400ex,440,450,465, and what ratio's pistons do you have. and what #'s did you recive
last night I did a comp test on my 450ex and got a 185psi reading IM planning on doing modds to that motor over the winter and will retest it then to see if the #'s respond hint's on testing 1. warm the motor 2. use a good tester (snap-on) 3. run quad with gas turned off till it quit's 4. test with kill switch in off pos. 5. crank motor with throttle in full throttle position . |
| All times are GMT -5. The time now is 10:17 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
