ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Honda (https://atvconnection.com/forums/honda/)
-   -   250R'S (https://atvconnection.com/forums/honda/53251-250rs.html)
Quadmaster24 Dec 16, 2001 09:35 PM
What parts from a 1988 250R will change over to a 86. Swingarm,A-ARM,Top end,fenders?
John Fahey 886
HondaMan85 Dec 16, 2001 10:02 PM
I know the plastics will change over, and the swingarm on the 86 is either one inch longer or shorter, i can't remember. The a-arms are one inch further forward on one of them but im' not sure which one.
KILLER250R Dec 16, 2001 10:22 PM
86-87 Steel swingarms
88-89 -1 inch aluminum swingarms
86-87 A-arms regular
88-89 +1 inch forward A-arms
The swingarms I don;t think are interchangeable, the A-arms are interchangeable. Almost everything is interchangable on them.
surethingtowin Dec 16, 2001 11:31 PM
The swing arm is interchangeable, just like everything else.
machwon Dec 17, 2001 04:35 PM
The top ends are interchangable but the piston and cranks need to be the same year.
86 crank = 86 piston
87-89 crank = 87-89 piston
or 87-89 crank with 86 piston but must use spacer plate.
ILoveHonda Dec 17, 2001 04:37 PM
You can make any of it work.
Dill Dec 18, 2001 09:25 AM
the 88 swingarm will NOT fit on an 86 frame, unless you don't want to run the rear engine mount, as the rear swingarm mount on an 86 acts as an engine mount too.
Warpig Dec 21, 2001 05:01 PM
yes you can
© 2026 MH Sub I, LLC dba Internet Brands
