Anyone else experienced oil leaks around the head where the head meets the cylinder wtih high compression race motor?
I used the Cometic gasket with copper cote and after about 10 hours oil starts seaping from the head gasket. Hasnt blown and lost compression but oil is starting to spray drops on the motor after a race. Anyone else had this problem? And if so what did you do to correct or what gaskets did you use? Could the copper cote be hurting the application?
get any kind of gasket you need and see if you can find this sealer called ''1211'' it is made by threebond and it is a silicon liquid gasket. worked wonders on my bike.[img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
I know exactly what you are talking.....do this, and you can run exetremely high compression and it not leak.....first use a metal head gasket, second, there are 3 long 6mm bolts that go all the way thru your rocker arm cover, thru your head and into your cylinder....if you can get extra torque on these three extra bolts, you can eliminate ever blowing a head gasket.....heres what you do, go to this site
http://www.barnbolt.com/lanl/cat_item/knsrthlk.htm
what you see there is a threaded locking insert....you drill the three 6mm bolts out to the outer diameter of whatever the o.d. of your insert, screw it in by hand, then tap the wedges in.....I think I used 1/4 inner threads, meaning I replaced my three 6mm bolts with these.....these work 10 times better than the crappy spring wire helicoil....gives you tons of torque....they work great for stripped frame holes, anything.
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
armpump450r
Technical and How-To Articles
04-01-2017 06:11 AM
JackOReilly
12-07-1999 09:12 AM
