86 Honda 200x clutch removal "Please Help"
I am trying to remove the clutch on my 1986 200x, can anyone tell me how to remove the clutch! I have the engine cover off and can not loosen the bolt that holds on the clutch on. Is there a special tool for this?
There is some type of pully/disc that is on the left side of the clutch, does that need to be removed? Please help Desperate in NY!!!!! |
you looking for a 200x motor??????
hint hint........ |
You take the cover off, you have already done. Now take out the 4 bolts that hold the springs on and pressure plate now you can slide out all of the clutch plates. I'm not sure on the clutch bolt I know on my YZ80 the clutch bolt had backwards threads that could be your problem, you shouldn't need a puller it's not on a tapered shaft
