yfz 450 won't start help needed
Old May 25, 2016 | 07:47 PM
glen30's Avatar
Default yfz 450 won't start help needed
My 06 yfz 450 will not start. It began when my son rode for a short time and it just stopped. It turns over but will not start....occasional backfire when attempting to start.
Here is what I've already done.
Has fresh gas and valve petcock is on
clean filter
has spark
cleaned carb A to Z
fuel screw set correctly
timing is correct
valves are in spec for both intake and exhaust
all electrical connections are good
tried a known working CDI from another yfz owner and no change to problem
I do have one relay in front that seems damaged...the two that appear identical....are these required to run the motor?
thank you in advance for your assistance!
Old May 26, 2016 | 07:05 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
You may want to ask this over in the Yamaha section to get more answers.
Old May 30, 2016 | 09:06 PM
r1nsho's Avatar
Welcome
Ross.B
Mar 9, 2016 11:47 AM
JunkQuad
Feb 19, 2016 10:59 PM
maveikfe
Feb 15, 2016 08:07 PM
Timbo2500
Jan 24, 2016 11:17 AM
keeperstweed
Jan 21, 2016 11:14 AM
