2003 sportsman 700
Old 08-18-2017, 06:16 AM
No break in time for this little seal but if the inner lip or outer edge was dry when you installed it,it may have taken a little times for the seal to get a little more supple so to speak for it to seal properly. That why most instructions say to lubricate the inner portion of the seal before installation and some even say to use a film of loctite around the perimeter of the oil seal to help keep it in place and to help seal any possible leaks. Ktm suggested using locktite on most of their seals and so did the service manuals on Vespa scooters that we sold for awhile. Good idea actually.
Old 08-18-2017, 06:57 AM
DVCM27's Avatar
Old 08-18-2017, 06:58 AM
DVCM27's Avatar
The attached photo of the polaris manual states not to lubricate seals.
Old 08-18-2017, 07:08 AM
They also say to use the seal protectors to install the seals also but most techs never did... Sometimes you can take the manuals instructions with a grain of salt. Inner part of the seals need to be lubricated as dry starts against metal are never good for them. Plus using loctite around the seals,I was hesitant too until Ktm and Vespa manuals started recommending it.
  #15
Old 08-18-2017, 07:21 AM
DVCM27's Avatar
I agree with you on the manual. Is it possible the seal is installed backwards? The manual didn't show a picture or give instructions. I installed it like the one that was there from previous owner. I'll attach a photo of the old stator cover with the seal in place
  #16
Old 08-18-2017, 07:25 AM
DVCM27's Avatar
This is the oil seal installed on the stator cover. This picture shows the crankcase side. The water pump seal is on the other side.
  #17
Old 08-18-2017, 07:30 AM
As best I can remember the small oil seal (8) closed end faces towards the outer case as shown in the parts break down.Open end is flush with the case.
Attached Thumbnails 2003 sportsman 700-5cbc2fa395f5624a9467fc599b4478cbf904c93e.png
  #18
Old 08-18-2017, 07:45 AM
Seal is installed correctly but looks like it's not quite flush. Don't think that'd matter that much though. Since you said that oil has slowed from dripping at the weep hole hopefully that's because the inner seal's becoming a little more supple and conforming to the oil pump shaft better.Again that's where I disagree with the manual on seals being absolutely dry.
  #19
Old 08-18-2017, 11:37 AM
DVCM27's Avatar
Ran it this morning, no leak!
  #20
Old 08-18-2017, 11:55 AM
What we used on all engine seals at the shop was Race Tech or Pro Circuit seal grease. We used it mainly for fork seals but great for other applications and a lot finer than most greases you can use.Race Tech Ultra Slick Grease - Motorcycle Superstore Red or green color,doesn't matter.
