KFX 700 CVT belt squeal
Just picked up my V-Force from service. They said the belt deflection was out of the specified range (2 inches). Seems odd the deflection is out of spec after about 25 hours.They removed the big shim and left the small one to take up the slack to bring deflection back to spec. I got it home and motored around a bit. When I am Drive or reverse and am stopped/idling the thing squeals like mad. When I am moving and the CVT is "hooked up" the squeal goes away. Called back the dealer and they said that is normal and after 1 or 2 rides the squeal will go away as the belt loosens. Does that sound right? Sounds like the thing is going to blow up when it squeals. I get more CVT whine while moving but it does Hook up and pull much harder now though!!
Jeff Roper
02-01-2022 11:48 AM
