how to change rings?
does ne1 know how to change rings in a bayou 220
Not sure about a bayou but on all the motors where i did chang piston rings i always needed a special ring tool.It is to remove the ring without damaging up the piston. You can use a hose clamp to compress the new rings and slide it over the piston to get in the new ones. its not to hard once you get the piston out of the sleeve.
