v force jets
Old Sep 8, 2003 | 06:28 PM
5150dunerider's Avatar
Default v force jets
which jets should i use with my new k&n filter i also took off the snorkel and cut the baffle out of the air box, also are the jets the round ones or the hex ones
Old Sep 8, 2003 | 06:33 PM
XC800's Avatar
Depends on your elevation. Check your plugs . If you are above 2000ft you should not have to change as the bike "should" be fat to begin with as it ships with jetting to 1500 feet. Where did you get your filter from? Airbox mods on the V are tricky. I installed 2 TPI valves and it runs best with the sliders cracked open only 1/2 to 3/4 inches. when I Opened them up I noticed reduced performance. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 8, 2003 | 06:39 PM
i usually ride at sea level i ordered my k&n through my dealer
are the jets round or hex?
Old Sep 8, 2003 | 06:44 PM
XC800's Avatar
You may want to jet the hex jets up!
Old Sep 8, 2003 | 06:48 PM
which ones do you think i should run i just ordered
the dmc aliens right now
Old Sep 8, 2003 | 10:27 PM
BuggyBrian's Avatar
The stock jets are round. With the duals you will should be around 150/155 to 160/165. I'm running 148/150 right now with the quiet cores. With open pipes it will need to be richer.
Old Sep 9, 2003 | 11:36 AM
XC800's Avatar
BuggyBrian:
What elevation do you ride?? I assune it is under a few hundred feet. I am still running stock jetting for now due to being at near 3000ft.
Did you do some plug tests to determine your jet size??
Old Sep 9, 2003 | 02:55 PM
are the outside of the jets hex or round i am still confused
one is saying round one is saying hex
Old Sep 9, 2003 | 05:32 PM
XC800's Avatar
Sorry, they are round. I thought they were the same as Keihin sled jets. I picked mine up today. removed/replaced with a small flathead screwdriver once the bowl covers are removed
Old Sep 9, 2003 | 07:21 PM
BuggyBrian's Avatar
5150,
I'm at sealevel here. HMF recommended 145/148 and I tried that at first. It was a little lean for my tastes, so I moved the 148 to the front and got a 150 for the rear. At your elev. you will not need that big of jets with the duals. I would guess like 140/145 to 145/148. Do a plug reading with a new set of plugs and run it hard (no idle). Good luck...
