How about the Bars?
It's time to get a new set-up.
Has anyone purchased the set-up from rockymountainatv.com? Trail Tech bars & clamp for $ 140.00 I'm open to any brand, just tired of the "toothpick " bars that are on there. Any advice on the swap-out would rock. Thanks |
How about the Bars?
I've put tag 2 bars with the tag mounts on two V Forces. You have to get longer bolts for the mounts to work and the choke cable has to be rerouted from the carbs to the bars or when you turn hard right it pulls the choke on. I've heard of others having this problem with other brands of bars also. I'd have to look again at the V's tho to tell ya what bend we used. I also opened the holes up on the dash panel so it could still be sued with the fat bars.
How about the Bars?
i got the trailtechs and they are sweet.the instrument panel mounts in flush.
How about the Bars?
I have the trail tech clamp with speedo adaptor and X-bars. Of all the mods I have done this was the best bang for the buck. The higher setup and the bigger bars improves handling 100%. I have much more leverage and it feels like the machine just lost 100lbs of weight. I live 5 miles from Rockymountain ATV. They are great to work with but they did not have the TrialTech set that I wanted so I ordered it directly from "Trailtech"..
How about the Bars?
I have the Trail Tech Logo clamp with Renthal Fat Bars. Great all around. Only a little hard to get the left rear brake lined up so it was comfortable to use for e-brake and as mentioned re-route the choke cable. Looks way better too!
Ken |
