Sticker removal?
Old Jan 18, 2004 | 04:07 PM
Customfabandweld's Avatar
Default Sticker removal?
How do you get the stickers removed. The factory put one on my headlight, and I cant get it off, without scratching it. I'm sure someone out there has a solution!
Old Jan 18, 2004 | 04:18 PM
FireFighter69ca's Avatar
The glue will loosen up when you apply heat to it. If you have a heat gun or a hair dryer, hold them by it, not to close with the heat gun. After a few minutes, just start pealing. It should come off with little trouble.
Stan
fidge1's Avatar
I just removed all the safety stickers off my predator--- what worked great for me was a hairdryer to melt the glue then scrape it with a plastic puddy tool, then use some glue remover and a smooth rag to get the glue offf-----mine came out awesome
Old Jan 18, 2004 | 04:27 PM
Thanks guys! Now if I can get the hair dryer out of the house without my wife seeing me.....[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 18, 2004 | 06:02 PM
Dangerous's Avatar
Pressure washer takes them right off and you don't take a chance of getting the plastic too hot. If you don't have one, just stop by the local carwash. This way you get a clean bike at the same time and momma won't make you sleep with the dog for using her trusty beauty machine for a purpose it wasn't intended.
Old Jan 18, 2004 | 08:00 PM
coolintheice's Avatar
If your wife won't let you use your hair dryer, I mean her hair dryer, just turn your high beams on and that should heat up the head light sticker.
Old Jan 18, 2004 | 08:08 PM
Thanks for the advice, I do have a steam cleaner, also.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 19, 2004 | 12:20 AM
Polaris500HO4x4's Avatar
get some goo gone, heat up the sticker with a hair dryer then use goo gone to finish the rest, works great for me
Old Jan 19, 2004 | 01:14 AM
ppags's Avatar
WD-40 is the ultimate sticker remover. Just spray it on the glue after you peel the sticker back a little, let it sit for a couple of minutes and it will come right off. It is also an awesome stain remover.
Old Jan 19, 2004 | 01:15 AM
tyzorg's Avatar
enough with the sticker post god.. he knows already *THREAD CLOSED* or is it? LOL aye.. i wish it was closed... *prays*
