HELP Engine Brake
Old Jan 23, 2004 | 07:19 PM
kawakasi's Avatar
Default HELP Engine Brake
My engine brake is on all the time
Any body know how I temporary dissable it and how do I fix it?
I know I could just unplug it but I would rather just run without it and still have 4WD
Any help?
Old Jan 23, 2004 | 07:24 PM
Prairiewrench's Avatar
You can unplug it and you will still have 4x4 and 2 wd. the light on your dash will flash back and forth from 2 to 4 but if you have the switch in 4x4 it will be in 4x4, if you have it in 2wd it will be in 2wd!
Old Jan 23, 2004 | 11:15 PM
kawakasi's Avatar
Do ya think my little black box from diamond G had anything to do with my problem?
Old Jan 23, 2004 | 11:20 PM
NovaKaw650's Avatar
How do you know its on all the time? Does the engine stall when you come to a stop?
Old Jan 23, 2004 | 11:25 PM
kawakasi's Avatar
Yes sometimes it does now with my new belt
but it didnt with my old worn out belt
you can hear it engage around 4mph and stay on any speed under that
even @ an idle
Old Jan 23, 2004 | 11:30 PM
NovaKaw650's Avatar
Sounds like the belt is too tight. If the engine braking servo was staying on, you couldn't stop, and if you did stop, the engine would stall. What type of new belt did you install, and what did you put back in for shims?
Old Jan 23, 2004 | 11:31 PM
Nope,not the modual, not a chance unless you did some majorly wrong wiring. Have you ever had the clutch cover off and possibly turned the key on while the cover was off? Try to reset the ebs. Check out the tech tips at,,,,, atvpower.com,,,,,, for reset instructions.
Old Jan 23, 2004 | 11:35 PM
Where in NW Iowa are ya, maybe I can help ya out?
Old Jan 23, 2004 | 11:44 PM
kawakasi's Avatar
Have not turned the key off with the cover off
My key is always in my pocket when i am working on it [safety first]
Goona try the reset in the morning anyway
Hawarden
bout 40 miles north of sioux city
Old Jan 24, 2004 | 12:10 AM
Nightryder888's Avatar
my 650 did the same thing, you can unplug it but the belt light will come on and limit your speed (mine did that at least) does the actuator make a screeching noise when it engages or when you shut your machine off? i took my old actuator apart after the dealer replaced it and it felt like the sensor in it was hanging up a little bit when i turned it. i would like to know how to disable the engine break if it happens again it is not worth the $234 to fix it
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
